Bead roller and mods.
A look at some of the shop tools for RewT.
Post Reply
Post by RewT » 14 Dec 2016, 19:47
This bead roller started out as the Harbor freight 149 special. I have had this machine for over 10 years. straight out of the box, this bead roller is a great tool. But like most tools, they can always be modified to make better. It does come with 3 different size bead roller, 3 different flange sizes and cutting die. I ordered a set of custom dies from Eastwood. I will post up info on the upgraded die set.
I started with reinforcing the back of the u shape to make it more rigid and not flex. I also added a small handle to the tighting bolt on the top of the machine to make it a tool less operation.
The roller is designed to put into a vise for use. and it works that way and I have used it for years like this, but I have now decided to make a mount for it to put on a stand. I am also going to be adding some custom parts to make it a powered roller.
Re: Bead roller and mods.
Post by RewT » 14 Dec 2016, 19:57
I don't have any before pictures of my bead roller, but this is what you get when you purchase it. Keep checking back for more pictures of the mods I will keep doing to this awesome tool.
Post by RewT » 16 May 2017, 18:52
Trying something new.
https://youtu.be/aUUA052uRPc
Post Reply
