It is currently 26 Jun 2017, 04:07
If you are new here and want to register an account send an email to info@rewtcustoms.com so I know your a real person and activate your account.
Post new topic Reply to topic  [ 8 posts ]
Author Message
PostPosted: 29 May 2013, 19:07
Offline
This is going to be a cool project, the owner has a lot of cool idea and plans for this car, He wants RewT to fix the rust and get the car ready for a lot of custom work. Check below for progress pics.
_________________
Top
 Profile
PostPosted: 29 May 2013, 19:27
Offline
And here are some pics.
The day we picked it up.
Front battery area that needs to be replace.
Floors before.
Replacement floors.
_________________
Top
 Profile
PostPosted: 29 May 2013, 19:31
Offline
And the last ones I got so far.
That is a 6 piece kit.
Tail light area.
Front fender.
_________________
Top
 Profile
PostPosted: 29 May 2013, 19:32
Offline
And the last pic of the car in the shop on dollies waiting for some work.
_________________
Top
 Profile
PostPosted: 01 Jul 2013, 06:01
Offline
These first group of pics are the removal and redo of the passanger fender apron.
Using the spot welder cutter.
Removing the old piece by piece.
And all removed ready for grinding.
This is the lower battery reinforcement. Didn't come with the replacement panel and nobody is remaking them. So broke out some tools and made my own.
Laying out the lines for the beads I will roll into it.
_________________
Top
 Profile
PostPosted: 01 Jul 2013, 06:03
Offline
And here are the after shoots of the front apron repair.
_________________
Top
 Profile
PostPosted: 01 Jul 2013, 06:09
Offline
And now onto the rusty floor repair. I did one side at a time, starting with the front section and then the rear. This is a 6 piece floor repair.
Some before pics of the rusty floors.
And the removal of the old floor.
This is a shot of an area I had to redo that wasn't part of the patch panel, once again had to brake out the tools and make my own.
_________________
Top
 Profile
PostPosted: 01 Jul 2013, 06:24
Offline
And here are the finished product shots. all the under metal was coated in a POR15 style paint.Then the floor was prepped with weld through primer then a fill primer. All the underside brackets had to be drilled and cut off, and then cleaned and re-welded to the new floor pan. Then the underside was undercoated.
And the pics of the finished product.
_________________
Top
 Profile
Display posts from previous:  Sort by
Who is online
Users browsing this forum: No registered users and 1 guest
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
cron
